M1 web interface
mustangcoupe
Has anyone else experenced that the M1 web interface seems to not work with the latest Java updates? I am running Java standard edition 6 on my laptop and I can not see the interface. But with Java Standard edition 2 on my automation machine I can get into it...
The page loads on my laptop I can see the title load on the tab (IE 7) but it stays blank
Spanky
Mustangcoupe,
Per your post, I just upgraded to Java version 6 on my PC and connected to the M1XEP with no problems.
What are you seeing on the connection?
Spanky
Try clearing the Java cache by going to Control Panel, Java, temporary settings, delete files.
trmitche
I noticed that it takes a lot longer to load since the latest Java release, but it still works for me as well on Vista.
mustangcoupe
I have 1.2.2 which the only fix I am aware of in 1.2.8 is the static IP for your ethernet modules. right? Should I load 1.2.8 ?
