RandyKnight
So now that I've figured out how to set up all my sensors on the bench (door and window, motions, glassbreak, and smokes), I need to plan out my zones. I have a large installation and will need multiple zone expanders. I'm trying to figure out what to do as separate zones and what to put in series. While I recognize this is a personal preference thing I imagine there are some best practices I should be aware of?
The home is a 5300sf two story with the following sensors to configure:
Motions: 33
These are a no-brainer to me as individual zones since they will primariloy be used for lighting control. With this many I will need secondary power besides the VAUX correct? What is typically done for that? Just add a 12V transformer to my can and split the load betwen that and the M1 VAUX? If that's the case I'm thinking I would put the ones I care about for security on the M1 so they'd be battery backed up and the rest on a separate transformer.
Smokes: 11
Wondering about this one. What is typical? Separate zones for each seems like overkill but all on one doesn's seem right either. Wouldn't you want to know where the fire/smoke is at? Maybe a combination approach, grouping together smokes from the same area of the house? Also, my smokes say they draw 75mA of current so I should be okay putting all 11 on the M1's SAUX correct?
Doors and Windows:
For the main hourse, there are 6 exterior doors, 2 garage doors and numerous windows. The windows are each homerun for maximum flexibilty but I'd think I'd want to put the windows in the same room together on a zone. The question is should there be more than that. Do you care if you know which room has windows open, or just that one is open?
Glassbreaks: There are 7 of these. Same question as above.
My general feeling is that M1 zones are relatively cheap so it seems like the more zones the better in terms of troubleshooting, flexibility ,etc. But that may be simplistic. What if anything am I missing in that?
BTW, be prepard to be inundated with Elk question over the next several days.
Motions: 33
Smokes: 11
Doors and Windows:
