Man implants RFID chip for automation purposes
I knew it would get attention if I phrased it that way :) On the other hand (no pun intended), I would be willing to do the same thing if I knew for sure it would be compatible with most HA/RFID systems out there :o
That's the only reason I wouldn't do this :) I am pretty sure that the chip this guy implanted won't be compatible with i.e. the iAutomate RFID system that is being tested with HS right now. But a band-aid approach might work here (stick another chip on top with a band-aid) :o
Was this predicted in the Bible couple thousand years ago?
Will it hold up to a lightning strike??
