McAfee Scriptblocker may prevent HomeSeer
PaulH
If your McAfee Security Center is updated and after you reboot HomeSeer does not start correctly, try disabling the script stopper under "VirusScan-Options-Advanced"
The "Hspi_ADI_Ocelot" script would not load, and I could not call up the HS screen until I turned off the scriptstopper option.
jlehnert
Norton does the same thing. HS tries to execute the startup script and "bang", everything comes to a screeching halt. Shutoff script blocking and everything is fine.
PaulH
The real bit*h of it was that this system worked fine for 2 1/2 years, it was only when the last auto-update downloaded the the problem started.
