hgupta1 said:
yeah, I want to go the cheapest route. And I have a w800 mounted pretty high, so I get good reception from the street. I am going to try the DS10a method. I'm not very familiar with relays though..where do I find a coil relay?
I wonder if there is a specific output port on my alarm system for external pagers. I don't necessarily want homeseer to be alerted everytime I lock or unlock the system.
Might be safer to use a transistor to drive a 12 volt relay. The coil reference just meant that the relay needs to be "triggered" by a 12 volt signal driving the siren.
A couple of gotcha's here. One is I'm not sure that your siren is actually driven by a 12 volt signal. You would have to read the instructions, look at a schematic, or measure it while on to be sure.
You also might want to drive the relay with a transistor instead of directly hooking it to your speaker output as it will ad a resistance to that output (and the drive capabilities are not known of the alarm system siren output).
As far as triggering HomeSeer everytime you open and closed your car, couldn't you fix this with code (i.e. siren must have sounded for a few seconds before notification)?
Sorry, I'm not giving you anything more specific, but I have to fix my truck right now (fuel pump).
