Multi-speed thermostat that works with OmniPro II?
jay01
If shopping around for a new HVAC system with variable speed gas heat and AC is there a proven thermostat that will interface to the OPII? Preferably via Z-Wave. It doesn't appear any of the HAI thermostats will control multi-speed/variable speed conventional furnaces.
I know you can put these furnaces in a dumb mode that allows a conventional thermostat to be used but I don't want to do that for obvious reasons.
Jason
ano
The Omnistat 2 can control two-speed systems. You might be able to find some third-part thermostats that can control 3 speed.  As for variable, that's usually a propriety system and only the thermostats from the HVAC provider are likely to work and you are at their mercy on external control, if they offer any.
neillt
The only ones I know of are Carrier Infinity, if you buy the $700 "system access module" that allows you to plug it in to the Omni....
