I have been using an ELK with X10 devices for a year and all was well until lately.
The X10 was becoming less reliable so I decided to upgrade to Insteon and added a new M1XSP and Insteon starter kit.
The M1XSP seemed to enroll fine and I upgraded the firmware to the Insteon only.
I added the required entries for about 5 lights (A1 and up) and the entries for 255 and 256 per instructions.
I turned on #256 and proceeded to link some lamp and appliance modules.
The first light seemed to work exactly as described and I could control it from the panel.
All those after the first were not successful. They appeared to be linked in most cases as the lights on the module blinked and then stopped blinking after I pushed the set button a 2nd time. However, they would not respond to the elk control panel after I turned off #256.
I tried several times each time clearing the link info on the new M1XSP (which appeared to work fine).
Could the existing X10 devices and M1XSP setup be causing interference --I still have the original X10 controller still connected to the M1.
Could I have signal issues with the Insteon that would cause this?
I setup the RF modules per instructions.
Should I try Powerhome and try to import in ELK . .and can I do this with only the demo version?
I'm using firmware 4.3.12 for the control and 50.0.22 for the Insteon M1XSP.
Any help would be greatly appreciated :lol:
Token
Token
