I've got 2 sump pits in my basement. One of which contains a pump and a back-up pump/battery back-up, while the other has just one pump.
I've been meaning to install a back-up pump + battery on the pit that has just one pump, and finally got around to it.
I've installed the Basement Watchdog combo pump (made it easier with just one outlet pipe plumbed there, plus this system had great reviews all over the internet). http://www.sumppumpsdirect.com/Basement-Watchdog-BW4000-Sump-Pump/p2753.html
The instructions note that this system can be hooked up to home alarm and automation systems, so that you can be notified when the back-up pump runs.
Below is a pic of the setup on the control box.
I'm running an Elk M1 w/ISY 994i. On the Elk, I'm running the wireless Honeywell. Also, I've got a few Honeywell 5816 wireless door sensors, converted to water sensors (theres a 2 port block inside the door sensor wired to screws with come out of the bottom of the senor). I'm thinking I could connect the 5816 door sensor to the sump pump, and use this as a notification...but I'm completely lost as to what part to connect to what part, and what settings to choose in the RP2 when programming that sensor.
Any help is MUCH appreciated!
Thanks.
Thanks.
