Hey folks,
Thanks for the wealth of information on this site. I have been lurking for sometime and learned a lot. My scenario is...I bought a house with an Aegis 3000 systems which appears to relate to the HAI Omni Pro II (if I'm incorrect please let me know). I know my only upgrade option for this board is new physical chipsets but what are my options, meaning which upgrade should I go to. I have researched and for the life of me can't determine which is the best and most logical choice. Any help is greatly appreciated.
I bought PC Access (User) and have familiarized myself with the menue from the control panels. I was able to set the IP Address and await the serial to PC interface cable. I am unable to connect via IP or serial at this time and only know what the system does via 'discovery learning' (lights come on at dusk, various relays, outdoor temp, multiple zones, etc)
I have no idea what the Installer code is but have the Master code and can access the settings via the control panel. I was able to change the User 1 code but assume this is not the same as the installer code. Any guidance to help me verify if my master code is the same as the Installer code would be awesome.
Since I am new and cannot post pictures or links I can tell you the currently installed eeproms have the following on them
first slot (U29) HAI 20A04-3 2.5
second slot (U30) HAI 20A05-3 2.0
third slot (U31) empty
Thanks and advance.
Skyfall
Thanks and advance.
Skyfall
