Hey Everyone -
I'm trying to wire up my first zwave switch. I've tried all sorts of combinations but with no luck. Here's what I've got going to my old 3-way switch:
1 bare wire (ground)
1 red wire (assumed a traveller to the other switch)
1 black wire
1 white wire
I've done a number of guesses and the best combo seems to be this:
switch black to wall black
switch white to wall white
switch green to wall bare
switch yellow to wall red
switch blue to NOTHING
When I tried the above, the green status led was off by default. When I flipped the switch to ON, the LED turned on but no lights came on.
I figure the blue wire needs to go somewhere... but there's no more available wires to put it.
Also - The secondary switch has a red wire, 1 gray (labeled common) and a black wire.
Any tips?
---- Edit ----
I pulled the switch off the other wall and I'm starting to think that perhaps what I had once labeled as the Secondary should really be the primary. It's just a hunch - but here's what's on the other switch:
There's a 14/2 and a 14/3 -
The white from the 14/2 connects to the white from the 14/3. I'm assuming that the other end of the white and black in the 14/2 leads to the light.
The "gray" from the 14/2 connects the "common" labeled spot on the switch
In the 14/3, the black connects to the switch as well as the red.
I have no idea where the "hot" is coming in from and where it's linking up.
1 black wire
1 white wire
Any tips?
---- Edit ----
