Need help with a solution for monitoring a door...
dsabot
Hi. I have an Elk M1 alarm system with 3 keypads. I have a troubled teen who has been turning off the alarm at night and sneaking out, then resetting when they get back home. I was looking for suggestions on a solution where I could get a text or phone call when the alarm is turned off after a certain hour. A phone call is preferred as I'd be able to hear that on my cell phone better than a text, but either would work.
Any advice?
electron
Administrator
Staff member
Can't you create an automation rule which triggers when the door opens/closes within a certain time frame (or if house is in night mode if you're tracking that) that will dial a phone #, or send an email?
dwalt
Off the top, why not write 2 rules like:
Whenever Area 1 arm state becomes disarmed
And time of day is later than 10PM
then dial telephone number
And time of day is earlier than 5AM
Everyone feel free to pick it apart
You might get a couple extra calls if you disarm at those times but you would know you did it so you could ignore....
dwalt
Or you limit when the user code works:
Whenever the time is 10PM
Then disable User 3
Whenever the time is 6AM
then enable User 3
When the teen tries to disarm the alarm after hours, it will fail and either the teen can't leave or the alarm will go off.
