I have a bank of six 100 watt outdoor floods that I need to control via a single Insteon switch. I do not require dimming, just a simple on/off. I am aware that the max. wattage for Insteon switches and relays is 480 watts and I wish to do this as simple as possible. The solution that I came up with is to use a Insteon ToggleLinc relay to power up the coil of a 110 volt SPST relay, then use the relay contacts to control the floods. Is there an easier alternative that any member might care to share before I proceed?
