Hi all,
I've been researching low voltage cabling for a few months, and I think I finally have a plan and I'm ready to order materials. Could you please check out my plan and let me know where I can improve?
I'm building a 3,800 sq.ft one-story home with a 450 sq. ft media room above the attached garage. I have hired an electrician to do the electrical wiring, and my husband and I plan to do the low voltage. Once I started researching my plan (and cabling runs) got larger and larger, so I want to make sure that I've covered the most important things.
I have a storage room near the middle of the house where I plan to put up a plywood board to mount all equipment. All cable will be home run from this panel.
Here's the plan:
RG6QS - 2 runs to each TV location (media room will have 4)
Cat 6, UTP, solid - 3 runs to TV locations (Media room will have 4), 1 run to each touchscreen location (located in most rooms), 1 run to Security Keypad (not in all rooms), 2 runs behind each bed (near nightstands), 1 run behind each major appliance in kitchen, 2 runs behind washer/dryer in utility room
22/4 Security wire - 1 run to each motion detector, 1 run to each window for future automated blinds, 1 run to each operating window for contact sensor, 1 run to each exterior door for sensor
Speaker wire, 14/4 or 16/4 (depending on length of run) - 2 ceiling mounted speakers in each bedroom (5 in master), 1 run to each volume control, 7 ceiling mounted speakers in living room, ceiling mounted speakers in hallways, powder rooms, front patio, back patio, 7? wall/ceiling mounted speakers in media room (need more work on this)
18/2 zip - 1 run to each window for future automated blinds, 1 run to each touchscreen location
18/4 Firewire - 1 run to each smoke detector, 1 run to each CO detector(not in all rooms), 1 run to each Security keypad
Shielded Mic wire - 1 run to each Security Keypad
I have calculated each run using a ruler and my house plan (and added an additional 20 ft to each run), but plan to double check the measurements after the electrician finishes.
I have calculated 4500 ft of Cat6, 1500 ft of Coax, 4000 ft of speaker wire, 3000 ft of zip, 4000 ft of security wire, 1000 ft of mic wire and 1000 ft of firewire.
I am having the electrician install multiple dedicated 20A circuits to the network panel (maybe 3?).
Other items to purchase:
nail plates to protect cables
velcro to bundle cables
punch down tool
smurf tubing to run empty conduit to each TV location
RJ45 keystones for terminating cat6
Plastic cable clips for mounting /supporting cable to studs
crimp tool
speaker connectors for terminating speaker wires
coax plugs
ceiling brackets for speakers
LV gang boxes or mud rings
Hardware for network closet: (This will come later. I am mostly concerned with pre-wiring now).
Patch panel
switch
hub
12V distribution box
stereo distribution
I will have a computer running Homeseer HS3Pro.
Am I missing anything big? Do I sound like I know what I'm doing? ;-)
I might add security camera locations and pre-wire for landscape lights (not sure how to do that yet).
Thanks for any help / advice you can provide.
Here's the plan:
punch down tool
crimp tool
coax plugs
Patch panel
switch
hub
stereo distribution
