Been doing a lot of reading and have decided on the Elk to get me going. I need help with my shopping list, though. It's hard for me to understand the function of some of the add-ons.
I want to get the controller installed so I can start wiring for some security to begin with. I have a two-story home w/access to the first floor from the basement and the second floor from the attic.
So, after the controller and a keypad (will probably ultimately be three), what else? Do many of you use the arming station for little-used entrances? Do you get a speaker (or 6 or 8) if someday announcements will be over the whole-house audio?
So many questions......In addition to the sensors, I plan on having several motion detectors throughout the house. Do I get some sort of expansion board to route all the top floor wires to? Can you then run a single wire to the control (in the basement)? Do you do the same for each floor?
What about the case....you think I should dump the Elk case and get something larger? I'm thinking much much larger. Looking at Automated Outlet pricing, however, it seems the package deals are the way to go. I get the case and a speaker. Where do you put that speaker anyway?
I apologize for the massive display of ignorance. There are probably other questions that I've already forgotten about. I doubt I'll have a handle on this until I can actually start using/playing with the unit. Instructions would also be nice.
Thanks in advance for any and all help!
Regards,
Mark
Regards,
Mark
