Nobody Home at Homeseer
upstatemike
Posted this on the Homeseer board a few days ago and got no reply... Anybody here have an idea?
I am doing a trial of Homeseer and trying to get the vws plugin to work. When I try to configure it I get the error below. Did I install it wrong or is this the problem already under discussion here? If I installed it wrong then any help troubleshooting my mistake would be appreciated.
"Server Error in '/' Application.
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS.
Source Error:
Line 58: ASP.NET to identify an incoming user.
Line 59: --
Line 60: authentication mode="Windows"/
Line 61:
Line 62: The section enables configuration
Source File: C:\Program Files\HomeSeer 2\html\vwscsv\web.config Line: 60
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42 "
Rupp
Mike,
Look in the web.config file for <authentication mode="Windows"/> and comment it out like this
<!--<authentication mode="Windows"/>-->
upstatemike
Rupp said:
Mike,
That did it...Thanks Rupp! I knew it had to be something simple!
