I have come to love this forum but, since there is so much info being passed around, it has made me a little confused. I am just starting to get into Home automation and would like to do the following:
1. Simple lighting control. Preset scenes, on/off schedule when out.
2. Control home theater equipment in family room.
3. Control sprinkler systems.
4. Ability to connect while away using a browser.
5. Use a touchpanel screen in central location and remote in family room.
6. Would like the family room remote to be touchpanel(tablet PC even)
and able to display family pictures when not in use as a remote.
7. Future link/control of thermostats.
8. Future ability for audio/video distribution.
I am thinking about using Homeseer software. Here is where my questions/confusion starts:
A. Is Homeseer a good choice?
B. Do I use Zwave, X10 or do both (even Insteon)? I want to use zwave
for lighting because of what I have read about x10 issues but, when it
comes to sprinkler control and IR transmitions, I do not know if it can
be done just using zwave? I have read about using an ocelot unit for
IR and I understand that it uses x10. Is that correct? Other options?
C. What is the difference between mainlobby and Maestro interfaces?
They are both offered on the HS web page and I am not sure if I will
need one or both? I am thinking about Mainlobby but wanted to make
sure.
D. Saw the thread about the controllers. If I use sfwr control with HS why
would I need a smart controller? This may be (OK, definitely is) a
dumb question from someone who is just starting to understand
things.
E. Am I restricted to one touch panel screen per PC? Do I have to add
more PCs latter if I want to add more displays? If not, will they all be
the same or can different screens be accessed from different units at
the same time? I am thinking about 15†displays from Dell.
F. What is the best way to cable for these displays?
G. How do I control sprinklers? What hardware do I need?
H. If I need an ocelot unit for sending IR commands to A/V equipment in
family room, where does the unit have to be? The PC running HS
software will be in a closet behind the wall where the touchpanel will be
installed so no need to run long cables for the display. However, I
think this will cause a problem when it comes to the ocelot unit.
I. Finally, what do you recommend for the remote control? Will I have to
use a tablet PC so I can access the HS functions through a browser or
can those functions be accessed through a standard remote with IR
and RF? I was thinking about the MX3000 but don’t think I can get
pictures to show on it’s screen when not in use. Now I am looking at
the fujitsu 3500. This only after I read a lot of negative reviews about
Ipronto.
Thanks again for all your help and reading through such a long list.
