NX1448E keypad can't set partition
JimS
In my recent issues with my NX8E panel I discovered that the NX1448E keypads don't have capability to change to other than partition 1 apparently. I have a NX148E keypad and just happened to use it when I added partition 2. On it I can set the partition and also a way to temporarily access either partition. The same programming steps are listed in the NX1448E but at the top of the section next to the title it says optional. Apparently I don't have the option? I didn't see anywhere that has more detail so it doesn't appear to be something I can enable. Anyone know more about this? I suspect the partition 2 keypad may be going bad so was going to swap them around and see if the problem happens again.
