At the commercial facility I’ve been working with for the past several years, they have an NX8E system used for security and access control with the card readers using the small key Fob’s. The issue I’m having now is adding additional Fob’s into the system. In the past 4-5 years, I’ve always used the following procedure which has worked fine.
This unit has a 595E module in it, and I regularly use DLX900 to look at the status, download event logs, etc. When I connect to the system and pull up the Main Control panel. All the current badges are shown in the Codes tab in the first 120 or so slots. The very last entry in here show Program as the number and our 4 digit code which is what it has been for many years.
So my question is, why won’t this code work from the keypad to give me access? Any help would be greatly appreciated.
Mark
- From keypad in server room, *5 then XXXX (system programming code). Ready light will flash if correct.
- Enter 002
- Press Cancel then enter the first available key FOB sequence you will be adding
- Present key FOB(s) to reader. It will beep. Wait approx. 5 seconds before adding subsequent FOB's.
- Exit to leave programming mode.
Mark
