jrfuda
I recently moved my IR emitters from my SECU16IR to a Xantech amplifed connecting block. The connecting block is connected to the IR out of my Ocelot using a Smarthome IR Linc (essentially an emitter and receiver bound together). This combination works very well - and I did not need the zoned output of the SECU16IR since I have no duplicate equipment.
Anyway, I think I've noticed an increased delay between commands, and I'm wondering if this is normal.
I used to have each of my 10 components connected to its own "zone" on the SECU16, and I often had to have lengthy delays (using HomeSeer, with a comma between each command and additional commas adding - maybe - 0.2 sec delay) Anyway, I had to have 3-4 commas between sequiential commands on the same piece of equipment.
Now that I have everything comming out of the Ocelot directly, my delays seem too long. Now it seems like each comma adds about 0.5 seconds between commands. Is this normal? Is this due to a finite speed in which the Ocelot can send commands via its on-board port, or is there something else going on, like my Xantech hardware buffering the output (which I don't think it's capable of) and letting it out a little at a time?
