Omnipro IIe 3.16 with recent reset, now getting unwanted beep from 5.7 touchscreens when system arms or disarms. Programming was not changed so thats not it. Tried turning sound off at touchscreen but the beep still comes through. Tried programming "When night delay then consoles disable beeps" also does not work. See underlined from manual following here:
Omni IIe Manual notes : Enable or Disable Beeper Programmatically Using HAI PC Access Software, you can create programs to either enable or disable the console or touchscreen beeper; individually or all devices. When the beeper is disabled, no audible beeps are emitted from the device, except for alarm conditions. All other beeps (i.e. entry and perimeter chimes, audible exit delay, entry pre-alarm, error beeps, confirmation beeps, trouble beeps, etc.) will not be emitted from the respective console or touchscreen. This may be used to disable the beeper in a bedroom at night. WHEN NIGHT: CONSOLE 5 DISABLE BEEPS WHEN OFF: CONSOLE 5 ENABLE BEEPS
Since the consoles were not beeping before the reset there must be a way to silence the notification beep when arm and/or off. Any thoughts?
