So, the other day, we lost power for second time this year. We have underground lines so it does not happen often. We immediately started having battery trouble issues.
Here is our setup. We have control in house with the stock 8Ah battery. I have a p212s in this box with a 12Ah battery attached to it. We have a box in garage that contains an expander Module M1XIN that runs off the p212s.
Here is a history of events:
5:51 Ethernet and low battery trouble.
6:04 Telephone fault issue and AC failure trouble and Power supply
6:27 CALL FROM MONITORING COMPANY RE: LOW BATTERY SIGNAL
9:44, 9:59, 10:52 Power supply (trouble i guess)
10:24 CALL FROM MONITORING COMPANY RE: BATTERY TROUBLE and EXPANDER MODULE AC POWER LOSS (GARAGE ZONE I BELIEVE).
10:52 Low battery restore
10:53 AC fail restore and Ethernet Restore and Telephone Line Restore
12:00 Control low battery trouble
When I got home at 9:30, i checked voltage on batteries. 8Ah was 11.99v, the 12Ah was 12.67
I checked batteries again once I got back from work at 4:53, 8Ah was 13.06 and 12Ah was 13.06. Battery trouble light on keypad was still on. The next morning, battery trouble light was still on, but by the time I got back in evening, everything was back to normal.
I thought the batteries would run much lower before having battery trouble. Does not system not test the batteries on regular basis?
We have a router that I use to check into system via ekeypad. When power is down, router is down. I was thinking of getting an UPS to connect router into this as well. Is there an issue with connecting an Elk to the UPS as well?
thanks.
thanks.
