Powerlinc USB???
dgeffs
To control X-10 directly from a PC I would normally choose a powerlinc. Is there a equivalent device that uses USB instead of a serial port. Seems like there are if I was using Insteon. Will the Insteon device work with X-10?
TonyNo
Unless I'm missing something, I use a USB PowerLinc. It's X10 performance is not that hot, though, and I believe that it does not support extended X10 commands.
BLH
The 1132U that was USB and had no internal controller to store stuff was nice if you only wanted 24/7 computer connected. I believe that one is discontinued.
