2 parts:
1. Is there usually a 'problem' with running several PLC protocols out of the same outlet? I noticed that if I put a UPB and X10 interface in the same outlet (off of an extension cord with a triple tap) then the PSC05/X10 does not work. Martin pointed this out in another thread but thought it may have been a bad power strip. Reason I ask is that I 'took over' a hall closet where previous alarm panel was and there is no power in there (alarm xformer was remote). I was planning on pulling a circuit from nearby room into there and tried plugging everything in there via extension cord. I have the M1 panel, PSC05, UPB interface at least. My concern now is after I pull the circuit in there, even if I break it out into several outlets, things won't work. Dilemma is its a difficult closet to get stuff in and I don't think I'll be able to pull several different circuits. Any thoughts - would some sort of filter allow it to work?
2. With UPB switches is it 'normal' to hear a 'buzz' when you press a switch, either on or off? It's not load enough to wake the dead, but it is noticeable. Is the buzz when the device actually transmits? I noticed in a rule that wasn't working (multiple clicks in another thread) it was because I was clicking the switch too fast. If I waited for the buzz after each click it seems to work. Is this normal?
Thanks!
Thanks!
