Is anyone using a dual graphics card setup with a normal monitor as the primary display and a touch screen as the secondary display? I can adjust the resolution independently on mine but for some reason I only get a full screen on the secondary when the monitors are set to the same resolution. For instance the primary is 1024x768 and my Lilliput 8" touch screen must be set for the same to see the entire screen. If I attempt to set the Lilliput at 800x480 I get a huge black bar at the bottom of the screen and windows will not display the lower third of the screen. If I set it to 800x600 the screen fills but much of the image is cut off. I've used Catalyst and Powerstrip to adjust the resolution and get the same results. Any suggestions?
Dale
Dale
