Problem - PCA file for OmniPro II 3.16, current version on controller 4.0B
MikeF
Hello All -
I was messing about with programming on my OmniPro II and managed to screw up my configuration.  The backup PCA file is associated with firmware 3.16, but the controller is running 4.0B.  When I load the backup PCA file into PC Access, it won't connect to the controller (I assume because of the firmware difference).  The new 4.0B file (missing most of the configuration) connects fine.
Is there a way to load the old config onto the controller, or failing that, a way to update the new file with the contents of the old - short of line-by-line, unit-by-unit?
Thank you much-
Mike
Thinking the file will get converted when you load it in to PCA with a connection to the 4.0B firmware.  Make sure your IP and keys are in place and then try to connect and upload the old configuration.  Then save it as a new configuration.
MikeF
Pete -
Thank you much for the reply.  I wasn't able to connect to the controller - if i loaded a 4.0b pca file, i could connect fine, but as soon as I load a 3.x pca file i can no longer connect.
Mike
