I just received my M1G system and am in the process of "benchtesting" the installation. I have all of the security related functionality tested and working correctly. The ELKRP software is able to connect to the M1G panel through the serial port successfully. I am now attempting to install the M1XEP ethernet module so that I can connect to the panel using the network and am having some problems. Here are the specifics:
The closet where I will be installing the M1G panel does not have wired ethernet access to the network so I am useing a wireless network bridge to connect the devices in that location to the network. I have the M1XEP plugged into a Linksys switch which is plugged into a SMC EZ Connect Wireless Network Bridge. I know that the the switch and wireless bridge are working correctly as I can plug my laptop into the switch and use the network with no problems. In this configuration, the ElkRP software is unable to find the M1EXP. I also tried eliminating the switch by pluggging the M1EXP directly into the wireless bridge, but that did not work either. However, if I plug the M1EXP into a switch that is hardwire connected to the network ElkRP is able to find the M1EXP. I really need for this to work wirelessly and I am at a loss as to how to resolve this problem and would welcome any suggestions.
Thanks.
Thanks.
