H
homeseer
Guest
I just recently installed x10 wall/light switches. They function manually ok, but wont respond to remote commands. What am I doing wrong?
homeseer, you need to do a bit of reading to get up to speed!homeseer said:Forgive me, as I am new to the x10 scene. All I did was install wall switches in place of the existing lighting switches. I set the code in the switch and pressed the appropriate button on the remote.
I am not certain what you mean by transceivers.
What exactly is a phase coupler.
How do I solve the problem of being on two seperate legs if this is indeed the problem.
Forgive my newby ignorance. I appreciate your help in advance.
I am guessing that you have a missing an important component between those two components.homeseer said:. . . All I did was install wall switches in place of the existing lighting switches. I set the code in the switch and pressed the appropriate button on the remote.
What remote?homeseer said:Forgive me, as I am new to the x10 scene. All I did was install wall switches in place of the existing lighting switches. I set the code in the switch and pressed the appropriate button on the remote.
:huh: Are you sure???rocco said:Oops. I meant the TM571 . . .Treetop said:I use the TM751, but as rocco mentioned, there are other models out there too.
ClearToLand said::huh: Are you sure???rocco said:Oops. I meant the TM571 . . .Treetop said:I use the TM751, but as rocco mentioned, there are other models out there too.![]()
rocco, you misunderstood...rocco said:ClearToLand said:rocco said:Oops. I meant the TM571 . . .Treetop said:I use the TM751, but as rocco mentioned, there are other models out there too.Are you sure???
Ok, I meant that little white plastic box that plugs into the wall and has that metal antenna sticking out about a foot. Not to be confused with the larger white plastic box that plugs into the wall with the foot long antenna that does the same thing, but a little better.
rocco said:...At a minimum, I believe you need a TM751 or RR501 transceiver to receive the RF signal and retransmit it over the powerline.
rocco said:Oops. I meant the TM571 . . .Treetop said:I use the TM571, but as rocco mentioned, there are other models out there too.
