Spanky
Many of todays over current protection devices are PTC (Positive Temperature Coefficient) Resettable Fuses. These are great devices because you never have to replace a blown fuse, but understanding how they work is important.
A PTC fuse should pass the rated fuse current without opening. For example a 4 amp PTC will not open at 4 amps or less. If the current exceeds 4 amps the PTC will start heating up until its temperature reachs the fuse cutoff temperature. 4.5 amps may take minutes to open the PTC, but 8 amps will open the PTC immediately.
In order for the PTC to restore, the current must be reduced to a point that will let the PTC cool off. If a circuit is normally drawing 1 amp and an offending 4 amp short is removed, the PTC may not reset because the 1 amp of current keeps the PTC hot enough to remain open. In this case the system will have to be powered down for a few minutes to allow the PTC to cool off and reset.
Another factor that affects the PTC opening point is temperature. The PTC is a temperature switched device, so if it is within a wall plugin transformer that is running 160 degrees F., the PTC will open faster than if the PTC was at 70 degrees F.
