wkearney99
I'm debating how to provide some on-wall termination for a bunch of in-wall wiring and get that's in adjacent structured media cans.
I've currently got three 16" stud bays side-by-side. They're in a 2x4" stud wall built out in front of the rest of the foam insulated wall. So there's actually a little more of the stud bay behind them as available depth. As in, with the current wall there's actually room behind the cans to snake wires. Not and even enough amount of allow for an extension ring, but enough to avoid crowding the top entry holes.
I'm not sure I like the configuration. I'm debating changing it from three 16" stud bays. I'm thinking it might be better to have the two 16" bays on the outside and a single 19" rack capable center bay. It's not a big deal to reframe this as it's just a wall specifically for this gear, it's not load bearing or related to the structure at all. I'd probably reframe it with 2x6" depth as well.
I really do prefer having the ability to enclose these items, so changing to a bare stretch of plywood isn't going to happen. So let's just not go there, please. That and I've already got the cans. Yes, I know, designing around existing gear isn't always the smartest route. We're not going there. Two of the six cans may show up in the For Sale section...
What I may also do is put a blank panel of plywood along the back of some portion of this rack-width bay. That way I'll have a flat open space to screw things down while also being able to cover it with rack panels.
The rest of the flat surfaces around & between the boxes will be painted finish-grade plywood. This to allow for removability should access be needed.
It would appear from Middle Atlantic's literature the width needed is 19-1/8". Sound right?
My questions are what width is desired and whose rails should I consider for it?
