evanlifetv
Hey all, I am just now getting around to re-writing my sprinkler control code for the new Rain advisory. This is where I am currently at, however it doesn't matter what value the "RaidAdvisory" flag gets set to in Haiku, my sprinklers never run unless I manually turn off the Rainadvisory flag. Could someone with a brain better than mine help me out a little? I would also like to create a "Run Sprinklers" button for those times when I just want a little extra water, is there an easy way to add that into this code, or better yet, do one of you have a much better and refined sprinkler code that you wouldn't mind sharing?
Thanks in advance.
1. // /////////////////////////////////////////////////////////////////////////////////////////
// IRRIGATION SYSTEM ROUTINES
// Each zone checks to see if Haiku Helper RainAdvisory has flagged before starting. If one
// zone is canceled, then the remaining zones are canceled also.
// System logs event if sprinkler activates or is bypassed by RainAdvisory
// Can also start any zone without triggering the others.
// If irrigation is attempted but stopped by a triggered RainAdvisory, then log that event.
2. TIMED 5:00 AM MTWTFSS
AND IF Bypass Sprinklers OFF
AND IF RainAdvisory ON
OR
AND IF RainAdvisory CURRENT VALUE IS GREATER THAN 40
THEN LOG RainAdvisory; Bypass Sprinklers
THEN SHOW RainAdvisory; Bypass Sprinklers NO BEEP OR LED
3. // If sprinklers begin normally (not bypassed by rain advisory), Then log the event and
// start the sprinkler program.
4. TIMED 5:00 AM MTWTFSS
AND IF RainAdvisory CURRENT VALUE IS LESS THAN 40
AND IF Outside Temperature CURRENT READING IS GREATER THAN 36
THEN Sprinkler Program Running ON
THEN LOG Sprinkler Program Started
THEN FLOWERBEDS ON FOR 15 MINUTES
5. WHEN FLOWERBEDS OFF
AND IF RainAdvisory CURRENT VALUE IS LESS THAN 5
AND IF Sprinkler Program Running ON
THEN BACKYARD ON FOR 15 MINUTES
6. WHEN BACKYARD OFF
THEN AC UNITS ON FOR 15 MINUTES
7. WHEN AC UNITS OFF
THEN MAILBOX ON FOR 15 MINUTES
8. WHEN MAILBOX OFF
THEN WEST FRONT ON FOR 15 MINUTES
9. // 9. WHEN WESTSIDE OF HOUSE OFF
// AND IF RainAdvisory CURRENT VALUE IS LESS THAN 5
// AND IF Sprinkler Program Running ON
// THEN WEST FRONT ON FOR 15 MINUTES
10. WHEN WEST FRONT OFF
THEN EAST DRIVEWAY/ISLAND ON FOR 15 MINUTES
11. WHEN EAST DRIVEWAY/ISLAND OFF
THEN EAST OF DRIVEWAY 1 ON FOR 15 MINUTES
12. WHEN EAST OF DRIVEWAY 1 OFF
THEN EAST OF DRIVEWAY 2 ON FOR 15 MINUTES
13. WHEN EAST OF DRIVEWAY 2 OFF
THEN ISLAND ON FOR 15 MINUTES
14. WHEN ISLAND OFF
THEN DRIVEWAY FLOWERBED ON FOR 15 MINUTES
15. WHEN DRIVEWAY FLOWERBED OFF
THEN LOG Sprinkler Program Stopped
THEN Sprinkler Program Running OFF
THEN SHOW Sprinklers Ran Today NO BEEP OR LED
16. WHEN RainAdvisory ON
THEN FLOWERBEDS OFF
THEN BACKYARD OFF
THEN AC UNITS OFF
THEN MAILBOX OFF
THEN UNIT 5 OFF
THEN WEST FRONT OFF
THEN EAST DRIVEWAY/ISLAND OFF
THEN EAST OF DRIVEWAY 1 OFF
THEN EAST OF DRIVEWAY 2 OFF
THEN ISLAND OFF
THEN DRIVEWAY FLOWERBED OFF
Thanks in advance.
OR
8. WHEN MAILBOX OFF
14. WHEN ISLAND OFF
THEN FLOWERBEDS OFF
THEN BACKYARD OFF
THEN AC UNITS OFF
THEN MAILBOX OFF
THEN UNIT 5 OFF
THEN WEST FRONT OFF
THEN ISLAND OFF
