reading static ram
dwalt
I've been trying to hunt down the locations for the installer codes and user codes on the OmniPro II.
There are three socketed static ram chips on the board. Two are 28C256 chips which my eprom programmer can read.
The codes are not there. There also is a Samsung K6T4008C1C-DB70 which is a 512Kx8 bit Low Power CMOS Static RAM.
My eprom programmer (GQ-4x4) can't read this static ram. I suspect the codes are there. Does anyone have a device that can read this chip?
dwalt
The K6T4008C1C-DB70 is a static RAM memory, not a non-volatile RAM. A static RAM loses its data the moment power is removed, while a NV-RAM will retain the data. So the installer code would not be stored here.
I'm not an expert on the OmniPro II, but my guess is that the installer code is most likely in the 28C256 somewhere, perhaps in encrypted form.
You could change the installer code a few times and dump the eeproms after each change. Compare the dumps.
You might want to check all the chips on the board and see if there's any other nvram types where secure stuff might be stashed.
