IVB said:
Anyone have any recent experience with electronic duct dampers (HVAC) , good or bad? I have a forced air furnace, need to balance out temps between 1st floor room. I have manual dampers on a few runs but its a monstrous PITA to go through crawlspace to the damper location, tweak it, wait an hour, etc. Looks like they're $100 or less, I could put them on half the runs and adjust it with a beer in my hand on the couch.
Yes did it in my last house. I would say in your case it might be helpful, but I can tell you, if you are retrofitting an existing system, its very tricky.
So I don't know where you live, or if AC or heat is the main problem, but there are a few things to think about. If you are just attempting to damper 1/3 the ducts, your probably O.K. but more than that, it becomes tricky. What type of blower do you have? Is it variable speed? Variable or two-speed compressor? If not it gets more difficult.
Long story short, when you close off dampers if they are much more than 1/3 of the total, and even that is pushing it, you may have problems. The design airflow over the coil slows, the burners have less airflow and run hotter, AC can freeze up, etc. and you WILL lose efficiency. I eventually got it working in my last house, but the blower and compressor have to compensate when ducts are closed.
I did mine for zoning, so in theory, you could set the temp of each zone and it would maintain it. It sounds like you are balancing the airflow with dampers. Mine were open or closed, no in between, so maybe yours are different. Can't you adjust the room vents?
Before I did the zoning many told me that a properly designed system requires very little closing of ducts. I didn't believe that so I did the zoning, but after doing I now believe those people were right. Dampers are almost never the right solution, they are just compensating for other problems.
I should add to this that I just replaced the 20 year old HVAC system in my house last week. I found a guy who was very experienced and not only did he replace the unit, blower, etc., but he also said the builder undersized many of the ducts and that cause problems. He replaced many ducts with bigger ones and it works great, without zoning or dampers.
Getting your unit to work correctly is an ART, and honestly, I don't think the majority of the contractors really know what they are doing. If you have the original builder system, 99.99% chance it wasn't installed correctly. A correctly installed and sized unit is a thing of beauty, but also rare in this day-and-age.
