Sacedog
I have the following system, that I will be replacing with an Elk.
I plan on installing the Elk in the basement, which is about 75' from the old Honeywell can. I have already tested contacts, and can use them with the Elk. So rather than running all of these contacts back to the Elk, can I simply wire a M1XIN and M1XOVR back to the Elk panel with 2 Cat 5 runs?
There are 6 2-wire contacts, and 3 4-wire motions currently hooked up to the Honeywell. I would use the M1XIN for the 9 contacts, and the M1XOVR for the 3 power wires for the motions. Does this sound correct? Does all of the power for those two cards come from the Elk?
