Hey all,
I'm starting to plan/prepare/save to wire my house I just purchased. The house has no Cat5, but has existing RG59/6 run throughout the house to some rooms via various splitters and barrel connectors throughout the basement and attic...so i figure while I'm pulling RJ45 to each room I might as well go ahead and pull RG6 too. Plus it'd be nice having a single clean line coming into a centralized place and splitting from there whenever i need it.
I have my 48 port RJ45 panel, will probably throw in a 110 or 66 block for phone even though i'm not currently using a land line...but I'm not very familiar with splitting off RG-6, my previous experience has just been with lots of splitters...and those always tend to go bad or mess up my SNR. What are some options out there for splitting off RG-6 that are of good quality, easy to use/keep things clean(both visual apperance, and Signal quality), and won't break the bank?
In addition to a distro block, should I be running RG-6 or RG6-Quad shield?
Finally...shortly after the wiring install, i'll be installing a security system, and a video surveillance system. Is there a standard for wiring for all security systems, or do they all use something special? I.E. can i pull some extra Cat5 into the attic and expect that to be sufficient, or are there proprietary cable connector requirements for most security systems.
Lots of questions, hope it's not too hard to read! Thanks in advance!
-Matt
-Matt
