Another question for you experts (and thanks for all of the other input).
As I work with my current electrical installer, I have quickly learned I am pushing the limits of his knowledge. Not to bad mouth him, just saying that he is not use to these types of requests / questions.
Well, I asked him to install RG6 QS solid copper through out the house. One of the things I read about this wire is tight bends are not good for it. When I asked him about what connectors he will be using he said the compression connectors since I have asked to put 2 RG6 and 2 CAT6 in each gang box. He said the compression will be better since all of these connections will be tight in the box and they will have to bend the RG6 90 degrees to make the turn up the wall out of the box. Should I be concerned?
Is there anything I can do to ensure best installation on this wire? I sure am doing a lot of research for this guy. I hope he uses it well
thanks,
Bill
thanks,
Bill
