RS-232 to RS-485 Serial Interface Converter
mishab
I need to connect TR-16 to my pc to get the thermostat log. For some unknon reason the thermostat is not obeying the rules and i need to troubleshoot why that is.
what is the simplest and cheapest solution to get the readings from the rs-485 device?
Is there a converter that can convert rs-485 to usb or ethernet interface?
mishab,
RCS also sells a converter.
I believe that you can get it from Worthington Distribution.
Just a thought.
Regards,
TCIII
Adicon also has a product called a Bridge that seems would work and is cheaper then the RCS unit. Worthington also has the adicon unit.
