I have a new Samsung 8 Series television that uses the Samsung One Connect system. It does not have any HDMI ports on the television. You make your HDMI connections to the One-Connect box and it connects to the television.
I want to locate the cable box in the closet with the rest of my networking equipment. There are two Cat 5 cables, properly terminated (they've been tested), running from the closet to the television set. I purchased the KanexPro HDMI extender to transmit the HDMI signal from the cable box over CAT 5 to the television set. Unfortunately, all I get is a blue screen on the television set; it is not recognizing the signal from the cable box. I tested the KanexPro with an earlier model Samsung television set with both a cable box and Apple TV and it worked fine.
Does anyone have any experience with the Samsung One-Connect system and HDMI extenders? Do you have a set up that works? Is there a different HDMI extender on the market that works? I see Leviton and LeGrand each sell one. Are these any different than the KanexPro? Or do they use the same technology? I hate to continue to toss good money after bad and buy another brand only to have it not work as well.
Any help would be appreciated.
Thank you.
Britt
Thank you.
Britt
