upstatemike
I was just down in my wiring closet doing some disaster recovery planning and I was struck by just how hard it would be to recover from any significant hardware failure.
The problem is that most hardware I/O is wired via screw terminals... a lot of screw terminals. Looking at my Stargate and each of the four expander modules, I realize that to replace any one of them requires disconnecting and reconnecting 16 digital inputs and 8 relays. That's 48 screw terminals per expander! Likewise each of my RS-485 hubs has 8 channels X 4 wires per channel for a total of 32 screw terminals per hub! The 24 zones in my Caddx panel is another 36 terminals, and so on...
No matter how you slice it, swapping one of these units out is not going to be a quick or simple task and will certainly involve significant down time.
So the question is: Why don't the manufacturers of these devices use the plug-in header type of screw connectors? Not only would that make equipment troubleshooting and swap-out quick and painless but also eliminates the risk of damaging a wire during the changeover. These two benefits are more than worth the trivial cost difference for this type of connector.
I think there ought to be a law that says any security, audio, or automation device with more than 8 screw connectors MUST employ removeable header terminals. I urge everyone to write their congressman. Lets get some legislative attention on this issue!
