Eric,
I recently purchased a solar w/RJ45 board and AAG wind from you. This is my first experience with 1-wire. I am using Weather Display to read the sensors. The solar sensor will, for example, be showing around 100mv reading and then go to 0 mv or 200mv occasionally. The conditions outside have not changed that dramatically.
I noticed this happening when I tested the unit inside on a short cable and the AAG wind not connected and now outside with about a 60' CAT5 cable and the AAG wind connected. I do not use external power.
The solar board is mounted in a 6" glass frosted globe (from a lighting fixture). Any thoughts would be appreciated. Thanks.
Bill
Bill
