upstatemike
Now that smarthome has dropped the prices on INSTEON switches I am considereing an unconventional use for them and I need to know if this idea will work. I want to use use two matching switches where one is X-10 controlled and one is manual but both have on/off indicators on the switch. My idea is to use 2 INSTEON relay switches where 1 is set to an X-10 address and the other is not (making it essentially a manual switch since I don't have an INSTEON controller).
This gives me matching switches with on/off indicators that can control CFL bulbs but the closet switch will not be automated. A couple of things I need to know before I try this are:
1- If you do not set an X-10 address does it default to A1 or is there truly no address at all? I don't want the closet switch to respond to all-lights-on or any other stray X-10 command on any house code.
2- If an X-10 address is not set, I assume the circuitry is still coupled to the power line. In other words I assme an INSTEON switch will suck just as much X-10 signal from the power line when X-10 compatability is not enabled as it would if an X-10 address was assigned.
3- Does anybody know if there is going to be an INSTEON Switchlink keypad that incorporates a relay instead of a dimmer? (not related to the above closet light scenario) I am converting almost everything to CFL bulbs to save energy so I don't have many places where I can install a dimmer keypad.
