Currently doing OTA TV with MythTV as the DVR. Also have some streaming services but recordings for those are in the cloud and only for some services. Probably getting Spectrum for internet soon when they run the cable in the street here so looking at what I would need for recording. This is in the USA in case there is any doubt on that. We have 3 TV locations. Haven't done cable in many years so need to get up to speed on set top boxes or similar hardware being used today. Think Spectrum has a cloud based DVR so that may be an option. Then there is Silicon Dust HD Home run Prime that uses a cable card that might work. If I could get the recordings into MythTV then a myth front end at each TV would be easy. Is DRM an issue on most channels or just on the movie channels like HBO? Does the STB have only HDMI out? I suppose I could try to get an HDMI splitter and recorder hardware to strip DRM (If DRM is even an issue) and use an IR blaster to control the STB but would really like to avoid all that.
