Hello all,
I'm about to move to a new (well, new-to-me) home, where I'll have to start nearly from scratch on security, whole house audio, lighting control, home automation, surveillance, irrigation, etc. In my current home, I have an HAI OP2, UPB lighting, Nuvo Grand Concerto, Rain8UPB, IP cameras, HAI Thermostat and temp sensors, and am running HaikuHelper, and I'm very familiar with these systems.
For the new house, my priority is to get the security system up and running within a couple of days of moving in, so the initial installation will be DIY and basic--and I will expand over time. Because of the design of the house (2 story, flat roof, no attic), wireless sensors are pretty much my only option for doors and windows right now. I will at some point replace all the doors and windows, and I will redo the roof. I'm thinking at that time there may be an option to run lots of wire, but that may still be a year or more off.
In the new house, there is an existing ADT system installed, but the previous owners apparently haven't used it for years so I'm not sure of the state. There are wired PIRs but the door and window sensors are all wireless and appear to be Ademco 5816. I considered trying to reuse the existing wireless sensors in the interest of expediency, but there appear to only be wireless sensors on about half the doors and windows so I'm thinking about just buying all new sensors (Qty ~40) and replacing the old ones
Given my familiarity with HAI and the investment I've already made (PCAccess, Haiku, HaikuHelper, [email protected], Automation Studio, HAI Music Gateway), I'm thinking I'm going to stick with the OP2. I'm thinking about a few non-security-related changes (RadioRa2 instead of UPB, Russound MCA-C5 instead of NuVo GC) but those will be topics for a later post.
One security-related thing I want to change, however, is to go with a GE Wireless solution instead of the HAI solution. I had many problems with the HAI Wireless stuff, and the new house is bigger so I like the idea of being able to use a repeater.
So, here is the first batch of questions related to security:
1. I see many choices for compatible GE Wireless security sensors. Can someone recommend a specific wireless door/window sensor that's relatively inexpensive (say $30-40 unit cost ), reliable, and less visually obtrusive than the 5816s? I'm thinking about sticking with surface-mount wireless sensors, to avoid having to drill the doors and windows.
2. How reliable is the operation of the 42a00-2 these days? An earlier thread suggested it had some quirks.
3. Is there a benefit to having a Quickbridge installed in addition to a 42a00-2? Somebody suggested it works well with keyfobs; is there some advantage to using the Quickbridge with keyfobs instead of the 42a00-2?
4. What is a compatible GE wireless repeater for use with the OP2 and the 42a00-2?
5. Does anyone know if I will be able to reuse the wiring from the existing alarm panel to the existing alarm keypad to connect an OP2 and 33a00 console?
6. Any recommendations for alarm sirens / sounders? The ones I currently have installed in my old house are, I think, the ELK 70. They are OK, but not meant for outdoor use and not terribly loud. Given the new house is quite a bit bigger than the old one, I am thinking I'll need more and/or louder sirens. I assume there is at least one which is part of the existing ADT system but I haven't seen it yet. Would I / should I consider reusing an existing siren with the OP2?
7. Are there any gotchas with reusing the existing wired PIRs? Will I need to change out EOL resistors?
8. Anything else I should be thinking about?
thanks!
--js
thanks!
--js
