Hello all,
It has been a while. About every 2 weeks all the outputs will shut off on a wc8. When I log into the gui I will see odd numbers or odd symbols in the ttl output bits section of the gui. And often times the 32 bit signed variables are large negative numbers.
I have the wc8 send me 1 email on reboot. I do not get an email until I manually reboot it.
I measured the ps and it seems rock steady at 9v and is a 1amp supply.
Thoughts on what could be causing the problem?
Tim
Oh, also, the gui clock stops updating until manually refreshed then the clock jumps to current time and all the values and symbols will change to some other value or symbol. Really weird. Other than this happening every couple of weeks it has been working fine.
If a network resource (like ISY994) send a command to turn on one of the outputs it will turn on the output for a period of time (5-10 minutes) but then shuts it back off by itself. After manually rebooting it (by killing power to the wc8 for 10 seconds) it works fine for another couple of weeks...
Tim
