Thx. That is what I was thinking of doing - I was going to run the powerline in metal electrical conduit - but I didn't want to presume that would necessarily help shield the control line from magnetic flux (for all I knew, it might increase it somehow).Guy Lavoie said:Some kind of metal sheathing could be added....
Curious, what is this control line doing?tanstaaf1 said:How can I shield a control wire from a power wire if they *must* run some distance very closely in parallel?
If the conduit is not grounded, then that could happen. But grounding the conduit properly will have the effect of draining any induced noise to ground and preventing it from reaching the cable inside.tanstaaf1 said:...but I didn't want to presume that would necessarily help shield the control line from magnetic flux (for all I knew, it might increase it somehow).
You probably just saved me a ton of money and work. I was about to begin ripping out large amounts of wiring put in place by a non-HA saavy electrician because he ran it in way many places within inches of power line (I think he was thinking in terms of doorbells and alarm switches). Now, at least, I will try and test it out for adequacy before I just start yanking.electron said:I have many Cat5E (used for sensors, video, IR, ethernet, ...) drops running along power wiring, some up to 40ft, and I have 0 problems. I will try to keep things seperate in the future, but I didn't have a choice with this house, I am just surprised how well it works.
QUESTION #2: GETTING MAXIMUM NETWORK SPEED FOR YOUR DOLLAR/EFFORT.royalj7 said:...It is always good practice to keep the low voltage wiring in a differnt stud bay than the power wiring. ...The one area that you could see a differnce is if you are trying to run a 1000baseT network. You have to get alot of things right to get true gigabit speed and things like termination and bend radius are probably more important, but proximity to power will increase the noise and inturn the latency of the network.....
