I hve just received a bunch of 18S20's for temperature measurement.
I assume that the temperature measuring element is theramlly linked to the Ground Pin so if I wish to measure a pipe temperature I need to make sure there is good themal contact between the Ground pin and the pipe.
Is this correct?
This seems not to be mentioned in the datasheet.
Is this correct?
