IVB
What network cable testers do you folks use to test your in-wall CAT5 runs?
I want to hardwire my 3400, but if i build the CAT5 ahead of time and test, then it won't be the exact correct length as I don't know it. If I run the wire, then terminate once it's out of the gang box, then I need one of those $150 network tester thingeys to test it. However, I don't know anything about those tools, and prices seem to range from $50-$500 for them.
I'll also use this to run probably 6-7 RJ45 wall plugs in various rooms, so I don't mind spending a little $$, but I'm hoping that it won't cost more than $125-ish as once it's done, i don't need it. eBay/used is fine.
