Testing your HA wiring
jlokanis
Several posts about DIY HA wiring have made reference to testing the installation or having a pro installer test their work as part of the install contract.
My question is: for DIY, how do you test CAT5 and COAX (RG6, RG59, etc)?
Are there some simple tools for this or do I need to rig up some home brew gadget? Is basic continuity ok or do I need something more sophisticated?
Thanks for any tips! ;)
-John
eufreka
Although more expensive, I would also suggest you look at the Ideal LinkMaster Pro XL
Overkill for a single DIY, but great if you might go deeper into the business.
A couple of key features: It does both voice/data cable and COAX testing. It can measure cable length (useful in situations when you didn't pull what's there, or when you wonder how much cable you have left in a spool. And it has two jacks on the tester, so you can test patch cables easily.
They also used to advertise a "security accessory kit" for additional testing of security/CCTV/security wiring.
http://www.idealindustries.com/Innovations/datacomm.htm
