I'm now working on a Windows PC (I'm a Mac user) and have a slight problem. The computer I'm using did not ship with a serial port. It's a Dell, so I ordered the part from them directly - it consists of a ribbon cable where one end plugs into the mother board and the other end has the serial port. I installed it - no problems. The bios sees the serial port as does Windows. Device manager reports that it is enabled and working properly.
But I couldn't get my weather station nor my GPS to work on it. One device said "com port busy" and the other said com port unavailable".
I called Dell support and hung up after an hour on the phone and getting transferred twice (sure not like the TV commericals).
Anyway, to make a long story short it turns out that the Windows service named "X10 Device Network" takes over the com port I added. When I disable that service everything works. Re-enable it and the serial port stops working. It's repeatable and happens 100% of the time so I know this is the problem.
What is strange is that a com port added with a USB/serial adapter works fine.
This is a real drag because I need that service running to receive signals from 2 of my camera.
Is this a known issue and if so is there any workaround?
Thanks !
Thomas
Thanks !
Thomas
