I have a newbie question about 1wire topology. I already have the following:
- a DS9097U adaptor
- a Power Injector module
- several Temp/Humidity/Solar... modules.
Most of the modules are to be connected in a star, so I will need a hub, too.
Because of cabling limitations I would like to do the following, I hope you can read the "schematics"
PC*
| 1m cable
Serial adaptor*
| 1m cable
Power Injector*
| 1m cable
Temp/Hum/Solar module*
| ~20m of cabling CAT5e
6-port Hub
All the other modules...
All items with asterisk (*) are located in the same room.
The questions:
1. Can I bring voltages to the 6-port hub via CAT5 cabling - using the Power injector I already have? It is somewhat difficult to power it locally.
2. Is it ok to daisy-chain one sensor module and the hub this way?
3. Any other problems with my plan?
Thank you in advance!
- a DS9097U adaptor
PC*
| 1m cable
Serial adaptor*
| 1m cable
Power Injector*
| 1m cable
6-port Hub
The questions:
