TS07 Mounting Question
Sacedog
I am going to be installing a TS07, and haven't received the unit yet. I am curious how it mounts in the wall? Does it come with a mounting box, and is it for "new work" or "old work"?
TIA
upstatemike
TIA
It has ears that flip up and down to grip the edge of the hole in the sheetrock from the back and draw the panel against the wall. If you don't have hollow sheetrock walls then I don't think there is any way to mount it (No surface mount option).
Sacedog
Yep. I'll be mounting it in a hollow wall, so the "ears" will work perfectly. Thanks for the info.
